...plus a PCIe HDMI/Component capture card.
I've been looking at something like that. Which one did you get? How do you like it? Does it capture & have an option for displaying Closed Captions?
Cheers
The intensity pro only capture in avi format uncompressed video.You will need a raid setup to use this card.
That is not completely correct. It has a MotionJPEG option which works for non-raid setups. I have used it on both PATA and SATA hard drives without a problem.
You are correct.Are you capturing the AVI file and encoding it to Mpeg 2 or H.264 format?I don't understand what you
would do with a large AVI format video capture.
Yes, you need a bit of buffer space to work with then post convert it to MPEG4/AVC or high bitrate MPEG2. Any BluRay, ATSC HD, or DVB HD standard works fine.
Here is something I recorded with it a long time ago and converted to MPEG2 at about 13mbps (not near as high as I should have made it).
http://txnj.net/directvhd/The%20Wild%20Sample.mpg
Limited time offer
