Multimedia Abilities? | SatelliteGuys.US
jcrash
221
Tulsa
I read the manual but it wasn't very specific. My question is - is there a way to play Burned DVD's (ISO's or otherwise) via the network from an HTPC on the multimedia portion of the hopper/joey?
You cannot do ISOs unless you have a DLNA server that will transcode them. The Hopper appears to play .mkv files just fine so you can convert them and they will play. I ripped a few SD DVDs to mkv and they worked with 5.1 sound.
There are several good free DLNA servers out there and Windows 7 has DLNA built into Windows Media Player.
Sent from my iPad using SatelliteGuys
signal loss
