Multiple LNB's on a Channel Master 1.2m Dish | SatelliteGuys.US
PopcornNMore
3,635
128
Gibsonia, PA
What is the best way to mount multiple LNB's onto a Channel Master 1.2m dish?
Last year I mounted a C-band LNB on my Channel Master 1.2m dish using clamps designed by (caddata) which worked very well, but now I would like to mount two or perhaps three LNB's onto the same dish. I am thinking of keeping the KU LNB centered in its black plastic mount and attaching a C band LNB and perhaps a DSS LNB on the sides.
So far, I have purchased a variety of conduit hangers and fence clamps to attach the LNB's, but none seem to work very well. Conduit hangers are not available in sizes larger than 2" to hold a C band LNB. Tonight I purchased a 2 3/8" fence clamp that works better, but I don't know how I should attach it to the KU LNB plastic mount.
If anyone has pictures of their setup of multiple LNB's on a Channel Master 1.2m dish I would love to see them to get ideas.
I know of 2 solutions for multifeed on a Channel Master 1.2 meter:
Official solution:
Back in the days of Channel Master, the company offered a multifeed solution. The reference is model 6067/01.
Here is a picture of it:
Then there is a non-official solution: DIY
Here is a guy in Holland "bambike" in forum Sat4all. He has his own DIY solution:
Hope this helps.
Charly20
That 6067/01 part is very interesting! I imagine it would be hard to locate, especially with Channel Master changing corporate hands, but it might not be a bad idea to check with Dow...
The DigiWave brackets look interesting, but I have a GeosatPro 1.2M dish which has a round, not square mounting arm. Does anyone know of a similar solution which will let me mount both my QPH-031 and GeoSatpro C2 LNBFs?
Here's my redneck rig for 123/129. Going to try to add 125 when I get the time. Just made from 1/2 x 1/8 mild steel and some scrap bolts and an extra lnb holder.
Official solution:
Hope this helps.
Charly20
This is exactly what I was looking for. Thank you very much for providing the information and pictures.
Wanted Address for TVtoyz
New to FTA
