Turd Fergeson said:
My zip is 36476. The channels I am trying to pick up are in Montgomery, Al. They don't show up on antenna web but they can be picked up in this area.
You are right, antennaweb shows very little reception from Montgomery, AL.
Go instead to :
http://www.2150.com/broadcast/default.asp
Enter Lattitude 31.3 Longitude -86.5 Range 90 miles
Scroll down to the antenna patterns and see how much power is aimed at you.
WDIQ-DT is closest, running 1 KW on channel 11.
WSFA-DT is at 600 KW on channel 14 but the antenna is aimed away from you.
WTVY-DT is running 97.7 KW on channel 36
WAKA-DT is running 736 KW on channel 55, the channel 38 listing may be their final channel selection for 2009.
You'll need the biggest and best antennas.
Lets say you get a VHF antenna for WDIQ, Antennacraft Y10-7-13. Add a Channel Master 4228 aimed at 36 degrees for WSFA. Use a second 4228 at 357 degrees for WAKA. Use a dual input preamp such as a Channel Master 7777. Add the two 4228's together with a jointenna tuned for channel 14.
http://www.warrenelectronics.com/Antennas/joiners.htm
My 4228 is on a 120' tower. I use 3/4" hardline to feed it. I can't use a preamp because I'm only 7 miles from the Albany transmitters. I've tried to get WTVH-DT in Syracuse, but I get a LPTV station from 47 miles away. (That's without a preamp.)
