I have connected a 2nd TV to one of my Hoppers in another room. I would like to have another remote for the other TV. Can I pair a 2nd remote to the Hopper?
NO, IR address #1 only.Can the 21.0 remote be used as in UHF mode as a second remote? and How do you "pair" it up w/ the hopper?
What's the range for a 2nd 40.0 remote? Will it go as far as a UHF? Anybody use one in a different room and it works good?
How do you change the remote address??? for a 20.0 IR and a 21.1 IR/UHF PRO???
2 questions: How do I add the 21.0 remote to work w/ my hopper? If I use the 21.0 in the room w/ the hopper(main tv) and use the 40.0 w/ a mirrored tv. What functionality do I lose by using the 21.0 w/ the main TV?
Limited time offer
