Multiple Remotes | SatelliteGuys.US
Multiple Remotes
TheWhip
2
I just got upgraded to a Dish DVR522. I have a question about multiple UHF remotes. It seems like I can only program 2 remotes at 1 time to operate the receiver. Does anyone know how to program 4 remotes to one receiver?
Any help is much appreciated. Thanks
I believe that both TV1 remotes must be on the same channel and both TV2 remotes must be on the same channel.
As long as they are on the same channel you can program any amount of remotes to control TV1 or TV2.
What exactly are you trying to do? You can have any number of remotes "programmed" to a receiver as long as they are on the same channel.
Trying to put two TV1 remotes on different channels defeats the purpose, because when you program the second, it changes the remote address on the receiver to match it's channel and thusly makes the first one inoperative.
annoying dish logo after update
VIP722 device code anyone?
