Multipurpose/Signal HD FTA Receiver | SatelliteGuys.US
bklee
3
From previous posts, there is a consensus that the Pansat 9200 is a highly recommended HD FTA receiver. In addition, their website posted a new DVB-S2 upgrade. With the exception of not covering 4:2:2/4:20, are there other signals/reception/capabilities that the Pansat 9200 lacks that other receivers have?
I take it the Quali-TV is the only receiver in the market to cover 4:2:2/4:2:0? Hopefully the Fortec Passion will also have this capability.
I guess with this hobby, you need to have multiple FTA receivers.
Unfortunately right now you kinda need more than 1 if you want to get everything you can. The Pansat does cover 4:2:0. It does not cover 4:2:2. At this point the Quali is the only set top box that I'm aware of that does 4:2:2. You are correct that Pansat is soon to offer a DVBs2 add on. You could use a pci card for 4:2:2 but, then you need a fast enough for computer (especially for HD) and most have no blind scan.
Next thing we'll need is Dolby E decoding.
Hooking a HD box to a HDTV through DVI cable
motor trouble
