multiswitch help | SatelliteGuys.US
multiswitch help
okaydave
37
This is my setup:
18x20 dish
1 HDTivo
2 standard recievers
1 OTA
Currently I have 3 TVs. 2 of the coaxs from the dish are going to my HD Tivo. The other two are going to the standard receivers.
I want to add 1 more standard reciever on another TV. How does the multiswitch work? Do all 4 of the coaxs from the dish go to the multiswitch or do only need to run one of them to the multiswitch and then I can add one more output to my 4th TV.
Thanks for the help
You will need to add a cascadable 4x8 multiswitch. All four outputs on your current dish will go to the inputs of the new switch. All sets will hook directly to the new switch.
HD Tivo quick question
view cable provider locals using receiver
