neo0285 said:I need a good multi switch that works with voom. I know i can order it online, i was wondering if maybe best buy or circuit city offer something that works so i could get it right away instead of waiting for delivery. thanx guys.
neo0285 said:i did get a multi-switch and its bad, and its a couple days before they can come out, so i wanted to see if i could fix it myself. I got the regular voom dish and stealth, but i am receiving the polarity problem with my system and i narrowed it down the MS, because if i just connect 1 receiver with a regular diplexer, it works like a charm
Both! There should be two connections between the multiswitch and the LNB.neo0285 said:should i connect the sat to the 13 volt or the 18 volt?
Thanx ilya for the help! what sucks though is my insatller didnt do it right, i had climb upon my roof and connect a second cable, so much for a professional installationIlya said:Both! There should be two connections between the multiswitch and the LNB.
Limited time offer
