Can anyone tell me if the Eagle Aspen 5x4 S-4140-GX is compatible with fta or not?![]()
This should work....
http://www.satelliteguys.us/fta-mpeg...ml#post1344314 (Switch setups simplified)
Add you Diplexers at the Receivers, and should be good to go.
yes they are. Its a powered switch so you do need to plug it in to make that work
Limited time offer
