Mutli Connection from 2 Dish | SatelliteGuys.US
arshad07
7
Hello Satguys
i have an unique problem with the multi connection ,Below you will see the
daigram, i have set up 2 Rcvr, if rectified i will increase to 4 Rcvr
view_pict.php
I've been at this quite a while, and don't see what your goal is.
Take a look at the Switches Simplified FAQ.
It shows a number of workable examples. :)
So, what sort of receivers are you using?
And which satellites have your fancy?
Adios ThisTV
Looking for a 4X1 powered switch or buffer amp.
