My guide goes out a lot. | SatelliteGuys.US
RobertSM
68
15
South Carolina
Seems like every other week my guide lists 'to be announced' on half the channels or all the channels. The only way I can fix this is a receiver reset. Anyone have any ideas why this keeps on happening or a perfect fix for it?
Thanks.
Receiver is an hr21/200
Sent from my iPhone using SatelliteGuys mobile app
What type of dish do you have ? 3LNB (one "eye" )or 5LNB (three "eyes")? Do you have an SWM system (one cable from the dish?)
If you actually have a 5LNB non-SWM then you probab;ly have a line of sight issue with the 119 satellite. What are your signals on 119 (all the transponders please)?
1-8 all n/a
9-16 All n/a
17-24 n/a n/a n/a n/a n/a 100 100 0
25-32 99 97 99 0 100 100 98 100
Transpnder 28 constantly switched between 18 and 0
Those are fine,TP28 carries spotbeams for locals to other cities, so low/zero signals are OK. But check the second tuner also.
Still thinking about the next thing to try.
Sounds to me like either an LNB issue, B-Bands, or the receiver itself just doesn't want to play nice anymore, last one isn't really ideal though. I'd say B-Bands or LNB.
