Hello!
This isn't actually a question but I wanted to share our network setup with others that may be looking into giving the CE & MRV a try. We have two Linksys WRT54GS routers, one is connected via CAT5 cable directly to our DSL modem (only 3mb
fastest available in our area). The other WRT54GS is running Sveasoft firmware which allows it to become a wireless repeater - meaning, the repeater connects wirelessly to the original router and allows you to connect to it via CAT5 directly into the repeater or wirelessly. Our HR23-700 is connected to the repeater via CAT5 (so it's on our network wirelessly) and the two H23-600's are connected via CAT5 to the main router. We successfully stream HD content via MRV on this setup. We do get the occasional glitch or digital artifact blocking but it's only become unwatchable once or twice. Pausing or stopping for a moment helped it get back on track. The few times we've had issues getting it all to connect up, a reboot of the receiver(s) or routers solved the problem.
I seem to recall that the general consensus is that a wireless setup doesn't work for HD content but I wanted to share that it can be possible. If you keep you expectations realistic (ie know you'll get the occasional glitch and realize that this is a beta testing program) I think you'll find you won't be disappointed and that it exceeds your expectations. I just want to thank SatelliteGuys and DirecTV for letting us be a part of the CE program and giving us access to MRV. Personally, I love it. :up
