MY MUDDLED THINKING? | SatelliteGuys.US
T4Runner
1,034
58
37.0N 119.5W California
I need to understand the process of the conversion of my 922. What is it that I am converting? Only the satellite listings you are calling the MAPS? I picked up the X4 in my listing by letting it sit on 105W, but w/o a subscription yet, can I watch any open or ITC DCII CBand channels with the 922?
How do I actually add channels?
I do have an OPENBOX S9 that works fine on all the ITC channels, but are there any IRC channels on DCII?
Sorry if my questions are innane, but I am fogged...
On the 922, you're just converting the EMM to the HITS universe so that you can sub. If you're not interested in subbing, then conversion isn't needed.
Yes, you can watch FP & ZK (ITC) DCII programming on the 922, as long as the channel in question is included in the maps (generic or otherwise).
Currently, you can't add channels to the 922. Once Map Master comes out, you will be able to add channels. The extent that you'll be able to customize will be known at that time.
Finally, yes... there are some FP & ZK DCII channels.
Cheers
Help receving Democracy Now feed
