My old wireless adapter not working get Dish Wifi or HIC? | SatelliteGuys.US
Goobzilla
18
Wellington, CO
1H/3J install last week that all works fine, but my TrendNet wireless gaming adapter (wireless signal in, ethernet connection out) does not maintain a good connection to my Hopper and seems to be causing Caller ID issues as well. Should I go with the Dish wireless stick or the HIC to get wireless to my hopper? Any chance Dish will comp me one since my system isn't 100% from the initial install?
Thanks,
Ron
The HIC will probably be more reliable, especially if you are having wi-fi issues at that location, which may be the case.
You can probably get it for free. Did the installer leave his number? They often do that, so you can call them if there are any problems instead of Dish which will ding their performance review.
Dish America HD package 34.99
722K with both 500 & 1000.4 ???
