My Recordings within DishOnline | SatelliteGuys.US
Wormbrnr
12
Katy, TX
Hi All,
I'm having issues watching my recorded programs with DishOnline. I can watch live TV without issue, however whenever I try to watch shows on the DVR is just shows nothing under "My Recordings". Tt does show the DVR is 6% full so it can see it. Anything you suggest I try?
I have a hopper if that plays in to it.
Hi All,
Please PM your account or DISHOnline log in and I can assist you with troubleshooting.
Mike, thanks for the quick response. I got back home and was actually going to screenshot it for you and it works all of the sudden. Odd. I travel again Monday so I'll give it a try then. Another question if I may. How do I move PTAT recordings over to "my" portion of the HD from DishOnline so it saves them for longer than 8 days?
Garys, thanks. Seems it came back for me as well. I'll try your trick if I run in to issues again.
From your PTAT folder, select the recording your want to save, press select on the remote. A drop down list should appear. Select SAVE from this drop down list and a copy is saved to your HD. The PTAT copy will remain until 8 days. If you have futher questions, please let me know. Thanks.
couple dish 1000? basic questions
I am replacing my owned 322 with an owned 722. I need to replace my dish 500, but which one? By my research it looks like the dish 1000 is what I need, and it looks like any version (east/west/.2/.4 will work here in MN? Just want to make sure I am on the right track Thanks
What is your dma? Nevermind, just checked for MN, all are on WA and only Minneapolis are on both WA and EA. A 1000.2 or 1000.4 with the WA lnb should do fine.
Thanks for the reply, I am not sure how/why I posted in this thread, thought I started a new one. Sorry OP. Brew
SlingPlayer application now asking for password after 922 update?
Can someone with AT200 confirm...
