My STB was Freaking Out this am - Broken? | SatelliteGuys.US
bdcrow00
31
Early this am, my VOOM started going wacko. Any time I select the PG, PG appears but the preview window alternates between the movie and a blank preview window. Channel is locked, ch up/down doesn't work, and the back key doesn't work.
Recovery requires a hard boot (unplug). Then the programming works fine with ch up/down or direct tune (number entry). This continues until I select PG again when it locks up as before.
Has anyone else seen this? My screen still showed V6.20. Do I need a new STB?
Brian
My STB was doing this at 2:00 AM last night. I did notice that a handfull of the Voom exclusive channels had a "Voom is experiencing technical difficulties, please stand by" message on them. I tried a reboot (power switch hold in for 10 seconds). After 15 minutes I had PG info available again only when using the channel up/down buttons. The VOOM button made the box do weird things. I shut it all down and went to bed.
This morning at 6:00 AM PST everything was fine. I had all of the Voom exclusives back and the PG was working just as good as new.
Whew! I tried over lunch and everything was fine here too.
Once again a happy VOOMer,
Brian
Happened to me too here in MD. I Just unplugged the box and it was all better. I thought it was something I did. Silly me.
Help in Indy
Will a larger non Voom dish work?
