Looking for some antenna advice, or do I just give up any hope
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id=8e03edea81e450
Yup, you are right I did not put a height in and I am I am in the mountains of Northern New JerseyThat is one fugly looking tvfool. I thought mine was bad
I dont know that area very well but the only time I've seen 25-30 miles away and 2edge with low db is in the mountains. I also noticed you didn't put a height. Try putting a height in there to see if that makes alot of difference
edit: I did a zip run at 25 feet and alot of the stations went to 1edge and above 10.0db NM
So before I suggest an antenna, please rerun the tvfool with various heights (or approx how high the antenna will be off the ground) and repost it
Thanks!
Didnt know NJ had mountains...learned something new
Oof...still doesnt look good honestly. You have a couple options
for full band (2-51) you'd be looking at something like this
http://www.solidsignal.com/pview.asp?p=HD8200XL&d=Solid-Signal-HD8200XL-Xtreme-Signal-Long-Range-VHF/UHF/FM-Outdoor-TV-Antenna&sku=700112818356&q=xtreme signal
You have a couple stations on Low VHF (mainly 3 which is MeTV)
If you dont care about VHF Low you can always try a smaller combo unit (smaller as in it doesnt have the long elements for VHF Low) like a HBU44 or HBU55 (which sadly arent made anymore but can be found) or the 7697
http://www.solidsignal.com/pview.asp?mc=03&p=HD7697P&d=Winegard-HD7697-High-Definition-VHFUHF-Series-TV-Antenna-(HD7697P)&c=TV Antennas&sku=
Another option is separate VHF & UHF antennas
It is up to you whether you want to spend the money and invest the time for a few stations. But note tvfool isnt an exact science. The channels that show below 0 in the NM category can **possibly** be picked up. On mine I have a station that is down in the -20 area yet it comes in at night pretty well (minimal glitches)
correct. But 2 of his stations that carry those subs (Me, Justice, Retro) are on VHF Low which requires a larger antenna. Folks in NYC proper have had issues with RF2 (where Retro is) and RF3 (Me, Justice) even with outdoor antennas. Channel 2 (WKOB) broadcasts at a "flame throwing" 300 wattsIf he can catch all the channels in order from WJLP to WKOB (which the first two look to be in the yellow and the others in the red) that are in the positive under the NM(db) I would say he can get some good subchannels like (Me, Justice, Laff, Antenna, This, Retro). Which would be under WJLP, WABC, WPIX.......
He's in the mountains (per his post above)...mountains can wreak havoc on a signal (and block it too)That close to New York City Market with the NBC, CBS, FOX in the negative (under the NM (db)).......
so true. It all depends on how much money and patience one hasDon't give up hope, but don't spend too much either.
Limited time offer
