mystified prof 7500 and skystar 2 | SatelliteGuys.US
ithacascott
6
New York
Howdy --
I don't get it - I can't get any horizontal transponders -- I am pointed at 97 and am using a linear lnb. I have tried my HTPC and my laptop -same thing.
Using dvbdream -- what is the correct settings for a linear lnb? Maybe this is where I am going wrong.
I have a Coolsat 6000 hooked to the same lnb (dmx522) and it picks up the horizontal and vertical with good strength and quality.
Thanks -
Scott
Ithaca, NY
Figured it out -- when using a standard lnb I needed to turn the 22khz switch to off in the diseqc settings. So far so good -- picked up the s2 version of FTV on 97. Seems stable for a couple of days. I am not using any switches or a rotor yet.
Ithacascott
PBS gone?
Tracker Premier System 70, any use?
