105w C-band
3760 V 28068
It shows up sometimes on Ku during a launch or live event.
NASA moved to 105W from 87W
http://www.satelliteguys.us/free-air-fta-discussion/272950-nasa-tv-moved-105w-87w-feed.html
Thelist in its current stage is DVB info updated by me. I havent yet sent the file to qwert1515 to get Nasa added on it
Hopefully with the new SatAv Micro HD coming out it will be easier to update thelist with S2 info as right now no editors are compatible with the program qwert uses
sadly that is the only DVB transponder on there.
I manually entered the info then aimed the dish to lock 105
I had a bugger getting it in
I went to 107 and locked that signal...then very slowly moved the dish until the signal was gone. Scanned and then 105 came in. This is on the 6 footer
..........By the way, On my 7.5 mesh dish I have the center plate with the (normal) quarter size hole in the middle. What wouwld happen if the hole was covered? Or does it matter?
Limited time offer
