I had started another thread concerning native resolution pass through where I indicated that I was conversing with E* tech support regarding the implementation of this feature.
It was my original intent to post the result of those discussions but I became so frustrated with the answers I was receiving that I lost interest. Recently another member sent me a private message inquiring about the progress of the discussions. It was then that I decided to post all of the correspondence exchanged between tech support and myself, so that all members would have access to this information. For some it may be a long read, and I warn you that I become so frustrated, and it may have shown in my last full message, that I contemplated cancelling my dish network account.
All of the information below was copied and pasted from the original emails.
Question
During the April 2006 Tech chat Dan Minnick indicated that a software update to offer native resolution pass through on the Vip622 receiver would be available by summer 2006. What is the status of this update?
Dish Network Reply
Thank you for your e-mail. The VIP622 receiver does pass any high definition over the air signal through to the television in native format, provided the signal is transmitted in native high definition. We hope we have properly addressed your concerns. If you have further questions you can respond to this e-mail or access our online technical support at the following link:
http://tech.dishnetwork.com/departmental_content/techportal/index.shtml
A Technical Service Representative is available via live chat 1:30 PM-10:00 PM (MDT) 7 days per week regarding your concerns. Please click the following link to use this option.
http://tech.dishnetwork.com/departm...al/content/tech/techchatadvcustformrf23.shtml
Thanks,
Joe B.
My Reply
Thanks for the reply,
But your answer did not address my question or the comment made by Dan Minnick. If my question had been passed to Dan Minnick for an answer I am sure it would have been properly addressed. I will attempt to phrase the question as simply as possible.
All of your HD receivers require that the user select a "TV type" (Vip622, Menu 6 - 8 - TV type) which modifies, or scales, the incoming signal to a particular (480i - 480P - 720P- 1080i) resolution, and passes it to the television. The question originally posed to Mr. Minnick was to add an option to the TV type menu that would allow the receiver to pass the signal it receives to the television with no modifications, or quite simply in its native resolution. Hence the term, Native Resolution Pass Through. Any modification, or scaling, would be accomplished by the television and not the HD receiver. When asked, on a previous tech chat in either March or April 2006, if this modification was possible, Mr. Minnick responded that the software changes to accomplish this task would be available by the summer. The context of the answer indicated that he was referring to the summer of 2006.
My question again. What is the status of the implementation of native resolution pass through, in Dish Network HD receivers, that Mr. Minnick indicated would be available by summer of 2006?
Dish Network Reply
Thank you for your e-mail. The display setting should be set to as high a resolution as the television is capable of displaying. The over the air antenna will pass through a high definition signal. This is referred to as Native Resolution Pass Through. An over the air signal, when it is passed through, is not processed by the receiver and simply "passed through" to the television in the format that is being transmitted over the air. This feature has been implemented. We apologize for the confusion, we are always looking for ways to improve our service, and we appreciate your input. We will forward your comments and concerns to the proper department; however, we can not promise this will be implemented. Thank you again for choosing Dish Network and please feel free to contact us again with any future concerns.
Thanks,
Joe B.
My Reply
Unfortunately, we are still on different pages. The question posed to Dan Minnick was concerning native resolution pass through for all signals both SATELLITE and OTA. The implementation of native resolution pass through will allow the television to scale the incoming signal to the native resolution of the set, and relieve the satellite receiver of any scaling responsibilities. Mr. Minnick stated that this update would be available by summer of 2006. What is the status of this update? I am positive if you posed this question to Mr. Minnick you would have the correct answer in less than sixty seconds
Dish Network Reply
Thank you for your e-mail. Your concern regarding native resolution is not particularly a valid concern as most local networks are transmitting up-converted HD signal which is not considered Native HD. Native High Definition Resolution is simply when the program is recorded in 1080i format with Dolby Digital 5.1 encoded; transmitted uninterrupted to the point of reception (your TV). At this point the TV will then be displaying Native Resolution. I must reiterate that most network stations are only transmitting up-converted HD. Due to this, it is physically impossible to transmit to the TV the actual resolution that the program was originally recorded unless by chance the receiver is on the resolution that the program is being transmitted. I would strongly recommend that you connect your off-air antenna to the TV so that it will display the transmissions for you. The only reason to connect this directly to your receiver is for the off-air digital recording capability. Currently, Dish Network broadcasts all of our High Definition programming in MPEG-4, 8-phase shift keying, 1080i format. Unfortunately, due to the lack of true 1080i Native Resolution, some of this programming is up-converted to meet these requirements. This is similarly true for all network afilliates.
Thanks,
Phillip J.
My Reply
There still appears to be a disconnect regarding an answer to the original question. I am the one who originally posed the question regarding native resolution pass through to Mr. Minnick on a previous tech chat. He clearly understood the question and commented that he had been in a discussion with a coworker prior to the tech chat that covered this subject. There was a segment on that particular tech chat, just prior to my question, that reviewed the native resolutions of various televisions and the corresponding settings in Dish Network receivers. There was never any discussion or question relating to OTA HD reception. Considering the answer, and the comments Mr. Minnick made regarding the discussion of this subject with a coworker, it was very clear to him that the question I posed dealt with passing the SATELLITE signal to the television with no scaling by the, in this case VIP622, receiver. All scaling would be accomplished by the television.
Based on the email answers I have received, I would have to conclude that Mr. Minnick's answer to me, and the discussion he had with a coworker, were misguided and totally lacked any foundation. I hope you have copied the various answers to my questions to Mr. Minnick, because he and an unnamed coworker, appear to have the same impressions I do regarding the advantage of implementing native resolution pass through of SATELLITE signals in Dish Network HD receivers. I am sure he would be enlightened by your answers.
I will close with this question. What was Mr. Minnick referring to, when he stated that a software update to implement native resolution pass through would be available by summer 2006?
Dish Network Reply
There was no reply from Dish Network
My Reply
There were two additional attempts made to get a response from Dish Network. The first attempt contained a copy of my last reply prefaced by the statement below.
I submitted the following response, and question, to you on February 20. Unfortunately I have not received a response.
The second attempt consisted of the following message.
The previous message, submitted Feb. 20, has not been responded to. The basic question in my very first message still remains unanswered. As a comparison, I submitted the same question to the August Tech Chat, regarding Mr. Minnicks April Tech Chat answer, and received a direct concise reply as shown below. Rebekah S. had no issues understanding the question, but it appears all other replies have been unable to provide a simple direct answer.
Question:
During the last tech chat Dan Minnick indicated that native resolution
pass through should be implemented by this summer. Is the implementation of this update on schedule?
Reply:
Thank you for your e-mail. The Tech Forum is correct, we are on schedule for native resolution pass through.
We hope we have properly addressed your concerns. If you have further questions you can respond to this e-mail or access our online technical support at the following link: http://tech.dishnetwork.com/departme...al/index.shtml.
Thanks,
Rebekah S.
Technical E-mail Support
Dish Network
Dish Network Reply
I have been waiting since March 13, 2007 for their reply.
Question
Dish Network Reply
Thanks,
Joe B.
My Reply
Dish Network Reply
Thanks,
Joe B.
My Reply
Dish Network Reply
Thanks,
Phillip J.
My Reply
Dish Network Reply
My Reply
Question:
Reply:
Thanks,
Rebekah S.
Dish Network
Dish Network Reply
