NBA on TNTHD - Where's the HD? | SatelliteGuys.US
vandalous
77
Keller, TX
While watching the HOU vs DET game on TNTHD, the signal started breaking up and all of a sudden switched to standard resolution. Now the picture isn't nearly as sharp and the sound is not in sync.
What happened? Anyone else experience this? I'm in the Sacramento, CA area.
Thanks!
NBA in TNTHD - Where's the HD?
:confused: Same here in the Philadelphia area. The picture is very soft & pixellated! Does anyone know what's going on??
technical difficulties.... Probably cause of the millions of election feeds interfering ;)
Had technical difficulties with the Mavs vs. Kings HDNet feed as well... After putting up the Dish Network Technical Difficulties screen about 20 times in the first quarter, they ended up replacing it with all things the Kings local feed, of which was zoomed in, looked terrible and couldn't read any of the graphics. Since the feed is only available in the Dallas area, you would think if they are going to replace it, why not use the local feed they are showing on 8405? Really nuts.
Just noticed that both channels are on the same TP. Anyone seeing problems with HBO HD which is the 3rd channel on there?
Just went to check for grins, and the HDNet feed is back up in HD and TNT-HD was doing the postgame interview of the first game in HD. Wonder what the Dish problem was?
It was mucked up on Voom as well. I tuned it in briefly, saw the Stretch-O-Vision and never went back.
It wasnt just Dish...saw some folks chatting on another board that were watching on cable that had same problems.
Looks like it was limited to the Detroit game only. The LA game and all the pre-, mid-, and post-game stuff were all HD. Odd.
Problem when exiting Dish Home
vmc site misleading?
