Is the NBC mux still up along with Montana PBS ? I don't get them anymore but I still get the national PBS's. Rescan doesn't get them either.
Hmmmm....may have to tweak the dish again this weekend. Getting Q=69% on the other PBS's which is better than before tweaking it last time.NBC mux and Montana coming in just fine at my location.
If you are having precipitation, Montana drops out quickly. Only solutions are to wait for better weather or use a larger antenna.Hmmmm....may have to tweak the dish again this weekend. Getting Q=69% on the other PBS's which is better than before tweaking it last time.
Larger antenna ? I like that idea !!!!If you are having precipitation, Montana drops out quickly. Only solutions are to wait for better weather or use a larger antenna.
Yes except this is a new GeoSat dish and I didn't have issues with reception before. But I still like the idea of a bigger dish and will be on the look out for one possibly for C-band.IIRC you have a 90 cm, and there was some vandalism/damage to it awhile back also? If you can afford it, you might consider upgrading to a 1.2m which should get you everything on 99 including all the wild feeds. There are dish resellers in CA that sell them, too, so if you have a truck or other means to pick it up, that could save you the shipping cost.
Limited time offer
