I am done with Sathero meters work great when you first get them, then after a while not dependable. Can someone suggest a top line Signal meter that does it all.
Thanks I was looking at the XR-3 the question I have will it work on C Band and Ku band on S2 channels?A dealer may be able to tell you about several makes and models. Assuming they give an honest evaluation. Anyway, I use one of the high end models - the Applied Instruments XR-3 with the VSAT-ACM module. For the most part it works very well. The only problem I have with it is the satellite ID which isn't reliable. I've had mine for about 2 years now. I don't use all of it's features though.
Sure, as long as you have module XR-TS2-01, XR-TS2-02, or XR-TS2-03.Thanks I was looking at the XR-3 the question I have will it work on C Band and Ku band on S2 channels?
Ok explain that I see they have them with and without a module ?Sure, as long as you have module XR-TS2-01, XR-TS2-02, or XR-TS2-03.
Yeah that looks good which model do you have?I bought an older version of a Dr.HD from Titanium Satellite a while back and I love it. It doesn't look like Brian carries Sat Meters anymore.
Dr.HD 1000 Combo
dr-hd.com
I have the 1000 S+ but it's been discontinued.Yeah that looks good which model do you have?
I had the 500HD it worked for a while and it wouldn’t boot, couldn’t get another battery for it, then it booted and it wouldn’t work right, so just put in the trash. You are luckyNeed2learn,
I guess I’m luckier than you with a my Sathero meter. I got a Sathero 300HD meter 2 years ago as a Christmas gift and it’s worked flawlessly, even after being dropped several times. Great battery time and easy to update.
It’s not a high end meter, but does the job just fine for me.
Good luck with your search.
John
I have the Dr.HD 1000 S+ and love it, purchased it from [mention]Titanium [/mention]last year I believe, but the tariffs made it not profitable to sell in the US. You can purchase the Dr.HD 1000 Combo from Dr.HD directly, there is a $50 shipping fee to the US.
Sent using Tapatalk
Hey EmCommSat I took your advice after trying out a Superbuddy 29 which is NOT for FTA and C band Dish, I ordered the Dr.HD 1000 S+ took about 10 days to get very nice, and thanks again.
Limited time offer
