need advice on dual tuner DVR | SatelliteGuys.US
e.saunder
10
Hi everyone. I`m thinking about buying DVR receiver. My question:
Can I watch live channel with analog audio on my TV set and record separate channel with it`s audio being outputed from toslink? If yes which receiver would you recommend?
I think you misunderstand how they work. The tuners and outputs are independent.
Go to the E* website for receiver specs.
Note that a current rumor indicates the "free" 522 lease offer ends on 4/14 - that means you must be INSTALLED by then or no 522 for you - you'd have to go with the 625 and pay $20 for the punishment - I mean privilege. I don't yet know how solid this is considering there aren't any number of 625's in the field yet, but that's what I hear.
Not only that, you can record on both, and watch previously recorded stuff on either/both.
Once you get the hang of using a DVR, you'll never watch anything "live" again. ;)
Missing any programming from 61.5 or 121?
Dish Add HBOHD/SHOWTIMEHD To HD Pack
