Need C120 LNB | SatelliteGuys.US
Need C120 LNB
techno935
1,048
Pompano Beach, FL
As stated, I need an LNB with a C120 fitting to replace the Eagle Aspen that I currently have on the feedhorn of the DTV dish. The noise figure is 0.9 db and probably contributes to a low signal quality.
I know Invacom has a few, but I was wondering if any other companies sold LNBs fitted with a C120 interface.
there are several replacement possibilities
the p-870 that should fit but its stacked Eagle-Aspen P-870
the primestar lnb should matchup to that feedhorn
also the Invacom's like you mentioned
whats the "fitted with a C120 interface" ?? is it the feedhorn.... if you have a picture
The LNBs in these pictures are C120, as I understand.
One is circular/DBS, and the other is linear/FSS band.
Unfortunately, I never got samples to play with, but those things are around...and cheap.
I think someone used one in a recent thread... let me look for it...
Yea, the feedhorn of the Eagle Aspen. I'd like to retrofit something else on it with a lower noise figure. It's for G10. To help the already weak signal from that bird.
Add on EDIT: It's almost been my one year of me being here! Already, over 400 posts and growing.
97w several radio channels now encrypted
Stumbled on the FTA reciever called Pico Macom SIRD FTA
