Need help connecting 2 FTA Dishes w/ Quad LNB and Ecoda 22Khz 4x4 Switch | SatelliteGuys.US
ProSatMD
Washington DC
I'm trying to connect two FTA Dishes w/a KU Quad Universal l Linear LNB on each Dish and a Ecoda 4x4 22Khz Tone Switch. The each dish is picking up one Satellite. ( Galaxy 25 & Telestar 12). Can not get a signal to come through to TV. When trying with a Dual LNB and no switch getting good signal. So the problem is probably the setup I'm using. Also not sure of the proper settings on the receiver (OmegaSat 5700). First of all, are LNB & Switch I'm using compatable? Any suggestions guys? Thanks!
22KHz switches are not compatible with Universal type LNBFs. Use a DiSEqC 1.0 or 1.1 switch instead.
The Universal LNBF has a built-in 22KHz switch for high/lo band switching, so an external 22KHz switch added into the mix does not work correctly.
Brian Gohl
Titanium Satellite
