Got a superdish 121 with Dp34 from eb*y. Tried to set it up and failed.
Using DP301 receiver and checked switch. It shows:
Installed Switch
P34
Input: 1 2 3
Satelite Conn x x
Polarity X X X
Device: Dual X X
Status: Problem detected, check connections
I switched cable on Dp34 and got same status.
Tested with ohm meter and no connection for 2 and 3 lnbs. the dual LNB is ok.
Does this mean I got a bad Superdish ?
Thanks for anyone help me out of this problem.
Installed Switch
Input: 1 2 3
Satelite Conn x x
Polarity X X X
Device: Dual X X
