Need Help plase | SatelliteGuys.US
Need Help plase
docj2005
294
st louis park mn
my visionsat iv 200 or what ever froze and the only thing i have now
is my dvbworld pcie 2006 card.... and i have never been able to get pc cards
to move my dish
the vision sat is stuck on gdmux
and does not let me use the remote aT ALL
i would love to use the pc card .. it works realy well
please HELP
thanls
docj
:confused:
Have you shut off the switch on the back of the Visionsat and tried turning it back on? I recall mine freezing up when I first got it in 2008 on what I think were HD or other feeds it wouldn't play. There a couple times I lost all my saved settings and had to start over again. Since updating to the latest firmware (version 1.45 I believe) I don't have those issues anymore.
Lately though, it has been having spells where horizontal TP signals are lost. The first time it happened the weather was bad - rain and snow - so I thought it may have been related to that. But it has also happened on good days too. Been trying to figure out if it's the receiver or LNB. Anybody else ever run into this?
Tried, or Reflashed and did not work?
Do you need the remote to flash, or are there buttons on the Front that you can use to navigate?
Does the remote have a TV / STB button, and the remote is set to TV?
Unplug the coax from the receiver (with receiver turned off). Then turn it back on and see if you can select another channel, or satellite, then turn it back off, replug the coax and see if that fixes you. Depends on whether that recevier will reboot to the last channel selected or not, or defaults to 1st channel in a master channel list, i suppose.
turbosat
    View Profile
    View Forum Posts
    Private Message
    Add as Contact
    Send Email
    Quote this post in PM
SatelliteGuys Guru
Join DateDec 26th, 2006LocationOneonta,ALPosts6,263
thanks to turbosat
I suggest updating the software on that Visionsat to 1.45
The software takes care of that locking up issue
Sonicview 8000hd no reception on 83w Ku
Satellite aiming laser pointer LNB
