Need help setting up a genie 2 | SatelliteGuys.US
BabblingXombie
2
Cookeville,TN
Hi guys I appreciate any help thrown my way!
I never setup a genie 2 before. I've setup hundreds of genie 1. What lmb do I use? What app do I use to setup...etc.?
Thanks guys
I assume you means a HS17. You need to have a mini client in order to us it and set it up. There is no app for it, unless you’re a DIRECTV tech which has an app they can use. What LNB are you using now?
