Need help understanding MOVING, Spot beams, etc... | SatelliteGuys.US
york4311
28
USA
I am in zipcode 55901, DMA 154 Rochester, Mason City, Austin and am stuck with SD Locals (I'm paying for locals 5.99 amonth)
I live 70 miles south of Minneapolis, and they get all locals in HD. I'd like to "move" my locals but not sure about if it would work or not.
Not sure what it is that I need to do. Is there anything I should check first...like signal strength, etc...
HELP!!!
HELP!!!
The Twin Cities HD locals are on Transponder 13 on SB14 on 129W:
http://www.satelliteguys.us/thelist/index.php?search=dn129?=true&sort=&order=&beamMap=CIEL2_SB14.jpg
and on Transponder 3 on SB 13 on 61.5W: http://www.satelliteguys.us/thelist/index.php?search=dn61?=true&sort=&order=&beamMap=E12_SB13.jpg
If you are pointed at 129W, go Menu 6-1-1 change the Sat to 129 and the transponder to 13 and see what signal strength you get. The transponder should change to be designated as spotbeam. If you get a SS above 30 you should be OK. Do a like procedure if you're pointed at 61.5 setting the transponder to 3.
I think based on your info you should be within the 129 spotbeam.
I want to add a third reciever, I need some info/help!!!
Dish Network Setanta Preview Information
