Need help with a 3 lnb dish | SatelliteGuys.US
thill_88
2
mi
:rant:i just moved to muskegon, mi from wyoming , mi and im trying to get my dish pointed in the right spot. i have 93% to 100% on the 101 but nothing on the 110 or 119. any tip are welcom thank you
are your settings correct on the dish? is the mount plum? could there be any obstructions to the right of the dish? Are you using any splitters or multiswitches?
thank you for the tips i tred them after work but no luck. the mount is plum and i am using the phase 3 nld with out any auther swiches. i must not a clear enugh view that i thought i have. how ever i can point the dish to get each sat. one at a time just not all three at once. any auther tips???
Jeep Superstars recording problem
H21 1080P
