Need Help with a TwinHan 1020a | SatelliteGuys.US
Wain75
2
Have PCI DVB Twinhan 1020a and have a 30 inch dish with a universal LNB. using Vision Plus and not able to view any channnels. Anybody with some configuration tips
thanks steve 336-847-1277
Hello and WELCOME to the SatellitGuys.US FTA forum!
If you are sure its a Universal LNBF make sure the L.O. is set to.......
9750-10600
Yes its a DMS International
Digital KU LNBF
Part No: DVB321-2
Input 11.7~12.75 Ghz LO: 9.75/10.6 Ghz
Output: 950-2150 Mhz NF: 0.6 db
I do not use that program , so can not give any software tips , other than what have already been given .
What sat do you have the dish aimed at ?
Are you getting any signal quality ? Often you can get some signal strength , just about any direction you point a dish . That does not get you a picture .
Wyr
List your favorite FTA bird and channel's
Well... I think I need help
