Need Help with Coship 3188 Searching | SatelliteGuys.US
Cliff45
2
Grand Rapids, MI
I have a new Coship 3188C hooked to a old Primestar oval dish with a new Invacom universal LNB that bolts on to the original feed horn assembly. I am doing blind searches and coming up with transponders and channels, but no picture or audio output. I checked the frequencies against Lyngmark tables and the frequencies are way over the ones listed for the satellite I think I'm on plus the PID's are WAY off anything listed. Still, I have great signal (85%+) on the meter plus the reciever says it's locked on something. Any ideas? I don't have any other equipment to try on my setup, as this is my first shot at DVB reception. I have installed several DirectTV setups for friends and family, but this (FTA) is my new hobby and I'm not having much luck with my setup!
Any help is appreciated!
Set your LNB L.O. setting set to 09750
As this is the setting for a Universal LNB, if that is not the problem try a factory default, and if that does not help contact your retailer for support, good luck!
