Need Help with DirecTV slim line dish. | SatelliteGuys.US
hosnatcher
2
Okay here is my dilemma:
I live in an apartment on the second story and my apartment Balcony doesnt face the southern sky. I currently have a DirecTV Slimline HD dish. My dish is mounted on my balcony railing but the weight of the dish is too much for the balcony to hold over time.
I recently bought a 3 foot tripod floor mount that can hold the dish but I need a pole or mast (5-6 feet) that is compatible with this large dish. I am looking to use the tripod mount and drill it into the balcony floor and put the 5-6 foot mast down the center and attach the dish on top. However I am having a hell of a time trying to find the pole or mast. Does somebody have any website suggestions or store suggestions were I can find one?
Many people have bought 2in OD aluminized steel from muffler suppliers....it's apparently standard muffler pipe...
That or fence post. It is slightly smaller than 2", so snug down those bolts!:D
2" OD pipe
solid signal also has a 30" mast an a 5 ft. mast for sale.
Pricey but easy to get.
You can get 2.00 " O.D. commercial fence post in long lenghts up to 8 ft if you diligently search google.
Doctor J
try cutting the foot mount that came with the kaku and self tap it the existing pole. just make sure its sturdy or ull have a hell of a time getting it leveled.
on and off signal on Sat 110
HR20 New Software 1/28 and 1/29
