Hi guys/gals,
First, let me tell you what hardware I have before I start rambling:
3 3100's (E469 firmware)
1 2700 (E451 firmware)
1 MCR 3x4 Multiswitch
2 SW-21's
2 dual LNB's
1 20" dish with twin LNB support
What I currently have setup, is a single "dual LNB" with 2 coaxial feeds coming in to the MCR 3x4 multiswitch, which enabled 4 IRD's to receive ExpressVU's 91 bird. This is working 100%.
Recently I decided I wanted to add a second dual LNB, to enable reception of the 82 bird which is used for ethnic/HDTV/other programming. I purchased a second dual LNB, and 2 SW-21 switches.
I installed the second LNB, and made 4 RG-6 patch cords. I took the 91 LNB outputs and routed them to "dish 1" on each SW-21. I took the 82 outputs and routed them to "dish 2" on the SW-21's. I connected the 2 outputs of the SW-21's to the 2 inputs of the MCR 3x4 multiswitch. This is where the problems began..
The IRD's won't detect the switches, and as a result I get 82 transponders in the 91 signal strength screen, and vise versa. I tried every configuration (swapping wires outside) but no matter what, I couldn't get the 82 transponders to stay on the 82 sig-strength screen, and the 91's to stay on 91.
I did some reading yesterday and learned of the SW-42. I was thinking of ordering one, but I'm thinking it won't help. Is the problem here my MCR 3x4 mutli-switch? Is this setup incompatible?
In a seperate installation, I used 2 seperate dishes - each with a dual output LNB, and fed the outputs in to SW-21's, which in turn fed only 2 IRD's. The setup yesterday was basically the same, except I used one dish (twin LNB capable) and the MCR 3x4 switch.
Could someone tell me what I need to do/buy/use to correct the problem I'm having here?
Thanks again,
Shaun
2 SW-21's
2 dual LNB's
Thanks again,
Shaun
