need help with G10R | SatelliteGuys.US
need help with G10R
lonewolf85
158
pocahontas ark
Hi everyone. I recently got a BUZZ FTA Receiver and I'm trying to set it up for G10R KU BAND. Useing a oval 39 inch by 29 inch primestar dish the dish currently set at 54 elavation, is that to high???? :confused::confused: I'm pretty sure the dish is to small, but it's all I got. So I would like to make it work. Also the LNB is a single output Hughs FSS type. I read on LYNG SAT that the transponder for most of the channels is 11720 V . I get a 71 signal and no quality no matter were the dish is pointed. I'm having NO LUCK at all. PLEASE help.:o:tux: Thanks!!!:)
Thanks That Was An Interesting Read. But It Really Does'nt Help Me. Find Out What Elavation I Need To Set My Dish At. By The Way I Am Located In North East Arkansas. Thank You:)
Primestar torroidal dish
I'm having almost the exact same problem here in SC. I had been
running a 30 inch oval primestar dish with a universal lnb at my house. It's been running fine for a couple of years. I decided to install a torroidal primestar dish with the same universal lnb five miles away.
I'm having no luck! I tried several times. I'm looking for the oval dish
to see if that's what makes the difference.
I got a piece of poster paper and have put the satellite coordinates
under the dish to aim them. It helps a lot.:):):)
ribbon cable.
4dtv 920 Split Picture Etc.
