Need help with superdish121 and 61.5 | SatelliteGuys.US
maharaj13
10
my current setup is superdish 121/119/110 to dp34 to reveiver 811. Is there any way to incoporate 61.5 into my current system to get the new voom channels? I still have the voom dish and an old dish 300.
any help would be appreciated
M13
M13
You're going to need a new switch. I don't think you can cascade switches to get four satellite inputs so you're probably going to need the pricey DPP44. The DISH300 is also your best bet to get 61.5.
Best solution depends on how many receivers need the 61.5 feed.
If 1-2, just add SW21 switches with the DP34 receiver feed on one, and the other gets the 61.5 DishPro LNBF (NOT a V* or Legacy E* LNBF).
Check to see if you can get a FREE 61.5/148 dish installed
3sat Installation Help Needed!
