need help | SatelliteGuys.US
need help
Greg R
6
Suwanee, Ga
I'm trying to hook up (2) additional recievers and need advisement on equiptment needed. I currently have the following equiptment from dish: recievers-510,301,2700,3700 + dish 500 with dual LNB+(2) sw21. I dont know how to tell if it's Legacy. Can anyone tell me what kind of swith to get or do I need to switch to superdish or other to accomodate.--Thanks in advance
Welcome to Satelliteguys!! :welcome
Let me move this to the DISH Network forum so you can get the answer that you need.
You have legacy LNB's and switches. The cheapest way for you to get the other 2 of your 4 receivers hooked up would be to buy a legacy quad. Replace the dual LNB's and remove the 21 switches and run two new lines to your 2 new receivers. Hook up all four lines from the receivers directly to the legacy quad. This is not the only way, but it will be the cheapest. You can find a legacy quad on ebay or perhaps on this site. Happy viewing.
510 dolby
Outdated EPG
