Need Help | SatelliteGuys.US
Need Help
stoker_x1
113
US
Has anyonee found the following "unit_32z.h"
If so post link Alot of us will appreciate that.
Thanks Stoker
This is one of the parts needed for the development of 4play. Right now, it seems to be missing. Please help find it and then post a link if you can.
Thanks, Stoker
Thanks, Stoker
The unit_32z.h, it is the header for the P&E api which is contained in unit32_z.dll. If you buy their cable you'll get the api :(
Bob in Lone Oak, TX
Thanks rbrothers,
I would like to find a copy of the file above to test the execution command, software only. I don't know which cable I want to buy yet. Have found several that might work, and some better than others. Just want to see how things work first.
Thanks Stoker
Bob in Lone Oak, TX
Is the dll file usable with other cables? If not, why would they make the software proprietary if it can't be used with any other cable?
920 With High Channel Count??
Err2
