Need help | SatelliteGuys.US
Need help
jimbolio
NC
I have a x2 satellite with 2 wally receivers, main works fine and is locked on eastern arc as it should be, the secondary receiver will not connect to the same 61.5 but continually reverts to satellite 119 and guide updating will not take place. Multiple tries with dish and winegard support no solution. Thanks for any help
If you already went into settings and selected 'Reset To Factory Settings' and then performed a satellite check switch to see if it's locking-in on the 61.5 satellite, and then finally exiting out and letting the receiver automatically update itself, and if that all still didn't render results then it's going to be a lemon.
I believe you have to hook up each receiver one at a time to the main and run a checkswitch so the receiver has the satellites stored in memory..
Reactions: pattykay
Dish Hopper 3 /wireless Joey's
DISH just lost a 20 year customer.....
