Need ideas | SatelliteGuys.US
Need ideas
DetFan
2,029
121
Livonia, Michigan
I am planning on adding a 5th box, but I will require another switch as the 4 ports I have are used up. Can someone direct me to an inexpensive one that would work best for me or does that not matter?
Switches DP34 and DPP44 could be connected by three in a row for up to 12 receivers/tuners.
Yea pretty sure im using the DPP44 right now, I see the other ports that say to another switch, so I am assuming that is where the next switch comes into play.
Actually I think I have the DPP44
Do you have 4 physical boxes right now or 2?
Menu 6-1-3 will tell you what kind of switch you have.
Are you aware that you can only lease a total of four (4) tuners, anything additional you will have to buy.
Need more info to better help you.
Congress pushing to resolve programming dilemma
