Need Info For FTA.. | SatelliteGuys.US
Need Info For FTA..
TheSage
4
Hi to all here and this is a great place for info.I will like to know if the stuff here i have is go or what is better.
1)Pansat 2500A
2)SG2100 And i have HH100
3)Winegard DS2076
Will i need better stuff then that please all th info is welcome...
That will work for 90% of the KU FTA channels up there, a bigger dish and a better LNBF (what have you got for a LNBF?) is about the only thing you could do to get any better, but its a great start.
damn...I didnt know they made a quad LNB for KU...I have a dual and a 3x4 multisiwtch to get 4 outputs :)
Its not cheap, but users report very good results with this LNBF even better than a single or dual versions with the same characteristics, for some reason!
I can get them they are 0.3 noise! Cost................... $130 shipped YIKES!
Universal Quad LNB 0.3dB Horn
A high performance universal LNB with an integrated feed-horn, and 4 independent switched outputs.
Typically used with fixed dishes to supply 4 receivers, in areas where the signal strength is poor.
Some users find that the Invacom Quad LNBs outperform the single and twin LNB in low signal areas.
Input Frequency
10.7 - 12.75 GHz
Output Frequency
950 - 2150 MHz
Noise Figure
0.3dB typical
Gain
50 - 60dB
Interface
40mm clamp
Ideal dish F/D
0.6
YIKES indeed!
For $130 I can get a few duals and a 3x4 switch :)
I just wanted one for G10, but I guess I'll use the above setup :)
Receiving NewsCentral on IA6
The Foxnet Channel On Mpeg2
