Need remote control help | SatelliteGuys.US
BCH
227
9
Atlanta GA
I have a 921 and a 811 connected to the same television. The 811 is not activated and is being used strictly as a second OTA tuner. The remote control supplied by Dish is not capable of controlling both of these receivers on separate remote channels and I don't want to use two remotes.
Is there an after market remote that is capable of controlling both the 921 and 811 when each receiver has been programmed to operate on separate remote channels?
Any programmable learning remote can handle both receivers. You will need to set each receiver to a different remote address.
It would sure be easier is Dish had enabled the remotes to control an E* receiver with the AUX mode.
Model 3000 Receiver with Dish 500
DISH 942 and Panasonic Remote
