Need remote help H20 + Olevia 532H | SatelliteGuys.US
Denman007
117
5
Hi.
Is there a way the get my H20 remote to work with my Olevia 532H TV? There doesn't seem to be a match when I search thru the TV manufactures list using the 'remote setup' on the H20.
Is there another way to program it or to get it to work?
Thanks.
EDIT: This is all I found...
Q: What remote control code do I use for my OLEVIA TV?
A: For the LTxxxxx series:
You can use the codes listed under RCA, LG, Philips or Yamaha.
For the 3- 5- 7- series:
This line of product is new to the market; STB manufactures have not included our brand in their code list yet. We recommend using a learning remote control for both the OLEVIA TV and your set top box.
None of those codes worked. I guess I'll try using the tv's remote for both devices.
I have the same problem with my Sony S300 bluray DVD player. The h20 sat remote does not have the code to work the bluray.:(
DirecTV's HD 100: The List Grows
Directv All Acess
