need some in on bud? | SatelliteGuys.US
lee espinoza said:
does bud have dvr/pvrs if so how much?
This is the bad/sad thing about the big dish, since not to many people use them anymore, there is no big demand for this type of box for a big dish.
the 4dtv dsr 922 is the latest model 4dtv box, the older ones are the 920 and the 905 the 905 is an add on box to any old analog box, any of them can be hooked up to a HDD 200/201 to get HD.
Good place to look for good deals is in the swap and shop section on the www.4dtvrocks.com forum's many people must get rid of there whole bud system because they are moving and can't put the bud up at there new location.
Like was said here before get a used dish and maybe a used box and do the install by yourself and you will save lots. If money is not a problem then a whole new system 10' dish 4dtv 922/HDD VC II+ c/ku feedhorn with lnb's will be about $2000 from a dealer. And you can always add a dvb box to your system for more programming from around the world.
If you are talking about taping show than buy a PCI card for your computer. There are some FTA receivers that have this BUT I think they go for 100s. The card should be under $100.
KTWO-tv ABC
MPEG artifacts?
