Need some tech help... | SatelliteGuys.US
Hi all. I have a Sony Blu-Ray Player. I would like to be able to set it up so I can connect to the internet via my wireless router. Do I need to connect something to the player to get it to connect? Here is the link to the online instruction manual if it helps.
http://support.sony-asia.com.edgesuite.net/consumer/IM/3452775111.pdf
Thanks in advance for your help.
Sony BDPS560 has WiFi built in. BDPS has video straming similar to the TVs. You would need to replace the 350 to accomplish what you want effectively.:D
You can also purchase wireless access point instead. It then act as though you had plugged in a wired lan.
Most Watched Disc in your Collection?
Blu-ray sales more than double while DVD slips
