Need someone to test something | SatelliteGuys.US
tvropro
On Vacation
6,872
I need input... will someone with a 905 go over to W4 channel 501 and see what EMM providers show up. Or someone that did the conversion go to diagnostics A 4th line down see if the 3rd entry reads "0" or "1" This info is needed ASAP.
Thank's TvroPro :)
TvroPro;
I have a 922, just finished getting the conversion done a couple hours ago. My Diag. A 4th line reads:
"0012001B00000000 FED4 0 1040 142 172 1"
I hope that helps.
Try going to W4 501 and post that line in diagnostics. I'm mostly interested if after the FED4 its a "0" or "1"
TvroPro;
I'm on W4-501.
My Diag. A 4th line now reads:
"0012001B00000000 FED4 1 1040 41 0 1"
Thank you. That proves it isn't in the new data stream. I heard it was active with 4160 I guess it was a rumor. It reads 1 on 4096 too so it's commercial only.
With my converted 905 I get a FE20 1 1040 on W4-501. EMM providers:2. Auth status MP.
W4-611: EMM 4096, 827. Hmmmmm.
Should I remove my Videocipher board on my 922 ?
Trouble on W1?
