Need SS for D500 @ 61.5 | SatelliteGuys.US
mrsat1
101
Seaford, NY
Can anyone (NE or East coast) post here their ss readings from the 61.5 slot.
Just had my roof re-done and wanted to get a ball park figure. Btw used a commdeck mount to mount my 2 dishes (61.5 & 110/119). Nice and solid mount. Didn't want to use lag bolts into the roof. Anyone interested try commdeck.com or sadoun.com and check for mounting D* or E* dishes. It will save you headaches and money down the road.....rolou21.
61.5 sigs
My 622 is reporting 65-75 on 61.5 from here in Eastern Maine. The Dish installer who brought the 622 said that those were typical for this area. I had preinstalled the dish, aimed it with a Sathawk and it was definately peaked. I would have liked higher readings, but that was the best I could get.
Good Luck, Eric
here in new jersey, i have 61.5 on tp 29 @ between 100 to 105
Thanks for the readings.....Some readings for example that I am getting are as follows using D500 w/dish pro lnb;
Xpndr 1---93
" 12-111
" 14-114
" 20-105
" 30-87.
So if this is ok please reply further.....Thanks....rolou21.
Xpndr 1---93
" 12-111
" 14-114
" 20-105
" 30-87.
Which Receiver to Chose
HD Receiver
