Need suggestion on diplexer | SatelliteGuys.US
pras
Just wondering if anyone can suggest a good diplexer. I need it for combining the dish network and comcast internet. Have only a single cable running into the home and don't have an option to run additional cable. Are there any downsides in using a diplexer?
pras
holland blue labe work but this could pose some issues depending on what dish box you have and what downlink and uplink channels they are using for internet.
shut off dish for winter
Unable to view the edges of HD channels
